Creating a Drawing within an Assembly using the drawing from a compnent inide of the Assembly.
I have been told this is possible to a have Drawing in a Assembly using the drawing from a component of that assembly?
Let me know if anyone has ever done anything like this?
Re: Creating a Drawing within an Assembly using the drawing from a compnent inide of the Assembly.
这个是可行的。
建立装配图一种方法是构建好组件再装配。(从下至上装配)
另一种方法是构建整个装配在拆分组件,或者在总装配图里建立组件。(从上至下装配)
You can add model views from a component on to the drawing of an assembly (aka view of part), but you cannot add a drawing (or drawing view) from a component on to the assembly drawing.
You can 'export' drawings from one part to another, but I don't think that's what you're asking.
Can you explain your requirement in more detail?
Regards, Ben
