Creating a custom parts list template
I am using NX10 with Team Center
I have been searching the internet and forums for ways to create my own custom parts list and I am coming up empty handed. it seems like because TC is involved, it is more complicated and i cant figure it out.
It would be very helpful if i can get a detailed (step by step) way about getting this probelm solved. I am relatively new to NX with anything other than modeling (like playing around with .pax files, attributes, etc.) and would appreciate a play-by-play solution.
for example, Information I want in the parts list....
[                           parts list        ]
[   number   ][   part number   ][   description   ][   material   ][      color       ]
[         1         ][        1234          ][        plate        ][          AL        ][      BLK         ]
[         2         ][        5678          ][        block        ][          AL        ][      WHT      ]
ETC. (descending order)
4 REPLIES 4
Re: Creating a custom parts list template
hI @bdemps ,
Please go through below discussion thread. It seems to match your requirement.
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/Customize-B-O-M/td-p/377267
Hope it helps.
@AmolKadam
Thank you for the recommendation. In the instructions, it says to go to file --> utilities --> customer defaults
and then go to drafting --> Annotations tab....however I do not see Annotations tab this as an option? See attached. I dont know where I am going wrong here...
Hi @bdemps
In NX 10, there was 'Restructure of the Drafting customer defaults'
You will find default parts list related setting in the drafting standard.
(view in My Videos)
Hi @bdemps ,
Please find below video:
(view in My Videos)
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
