Creating an eclipse on a rotated plane to see a perfect circle from the original coordinate system?
I am very new to NX12 and have a question
I have a series of points along 3d edges that i want to ROTATE to a plane so i can generate a 2d profile
How can I do this
Re: Creating an eclipse on a rotated plane to see a perfect circle from the original coordinate syst
Hi Frogdude01,
you can connect the points with lines, make a 'Revolve' to produce a sheet body, and then intersect it with a plane (using 'Intersection Curve' or 'Section Curve'). Then you can put points on intersection line segment ends.
WZ
