Ctrl+z comand_more steps backwards
Hi everyone!
I have problem with ctrl+Z command in NX. It works only 3 steps backwards. There is any way to set it for more steps?
Best regards
lukipap
3 REPLIES 3
Re: Ctrl+z comand_more steps backwards
Check your Undo File Size in Customer Defaults. It may be set to a very small size.
Also note (From Documentation)
" The undo list is refreshed each time you switch applications, change work parts, or save the work part. While you are in a specific task environment, such as Sketch task environment, a temporary undo list is created for that environment. This temporary undo list is deleted when you exit the task environment."
Thank you!
