Curvilinear dimension in NX drafting
Hi NX Community,
I am trying to find a way to mark a curvilinear (girth) dimension for this part. I am unable to find a way to do it.
My request is if someone can help me out.
17 REPLIES 17
Re: Curvilinear dimension in NX drafting
Are you looking for Arc Length dimension?
Samadhan
Siemens Genius Siemens Genius
Siemens Genius
Hi @Junaid_Abbas ,
Try using Point to Point or Perpendicular dimensioning method from Rapid dimension. It might help.
Insert > Dimension > Rapid > Method > Point to point OR Perpendicular
Amol
Hi @AmolKadam
I am trying to mark a curvilinear dimension, I am unsure if it can be done the same way as you are describing.
Anyways thanks for commenting.
Hi @SamadhanGaikwad
No, I am not looking for an arc length. I am trying to mark a spline dimension or curvilinear dimension.
OK. Which NX version are you using? Please add tag to post.
Samadhan
@SamadhanGaikwad
We are using NX 12.0.2.9.
Siemens Genius
Hi @Junaid_Abbas ,
Dimension like this?
Amol
@AmolKadam ,
Thanks for the effort, I am looking to give the dimension as shown in the image.
@Junaid_Abbas , this is not supported yet.
You can report an IR requesting the same giving reference to this.
Samadhan
