Customer Defaults to Session
Dear Community,
is there a solution to "inherit" the two line tolerance text height from a site drafting standard to the global session? (So i don't have to write a journal or else for this)
Re: Customer Defaults to Session
Menu > Preferences > Drafting. In 'Inherit' section select the 'Settings Source' as 'Customer Defaults'.
Ganesh
Thank you for your hint, but here also the user have to be involved. I'm looking for an inbuilt-automatic way to do this.
I am not sure if there is any other/automatic way.
If you decide to go for the journal. There is one sample code available on GTAC which may be helpful to you. It's a NX Open .Net C# program.
inherit drafting preferences from customer defaults
Ganesh
You can import the setting into the base templates (seed part) so that every time you create a new file the setting is in the part
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
