Re: Customize B.O.M
Hi Ben,
the answer for "are you referring to the Drafting Parts List?" is No, I am not.
I am referring to Bill of Materials in Mold Wizard app.
As we know, we can export a spreadsheet (excel) in BOM command from Mold Wizard,
I attach a default spreadsheet sample that created by BOM.
a header Siemens Industry Software . . .  is created by default,
and there are <CUSTOMER> and <PROJECT NUMBER>  columns appear by default.
Well, Can we customize that spreadsheet (excel)? Like, changing the header, columns, etc.
I am glad to wait your response.
Thank you
Re: Customize B.O.M
Hi @JoDi,
In %UGII_BASE_DIR%\MOLDWIZARD\templates\bom\ you will find ReadMe.doc which explains which portions of the BOM templates can be edited.
Regards, Ben
Re: Customize B.O.M
Hi @BenBroad
Thank you very much for the advice, I will study it.
Re: Customize B.O.M
@mgd-genuine
This may be a little convoluted, but in order to get associative model size in NX 10 you could use the mold wizard 'Create Box' command based on the solid body of your model (using 0 offset) and then create associative measurements for the X, Y and Z edges of the resulting block. You may then reference those expressions within your parts list.
Abe
Re: Customize B.O.M
@mike_fdo
 In the instructions, it says to go to file --> utilities --> customer defaults
and then go to drafting --> Annotations tab....however I do not see Annotations tab this as an option? See attached. I dont know where I am going wrong here...
Re: Customize B.O.M
@bdemps , It's available in Customize Standard -> Table -> Parts List.
Other simple way to find the needed default in CD is just use "Find Default" button at the top-right of dialog and search it.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
