Customize <TEMPLATE_NAME>
When I insert a part from the reuse library with the clone option, I need to customize the <TEMPLATE_NAME> in order to modify the name of the new part with some parameters from the spreadsheet, depending of the user choice. Is there any way to do it?
Any suggestion will be welcome.
Re: Customize <TEMPLATE_NAME>
Hi @Frank,
I tested out the functionality and couldn't find a solution and then found a similar request has already been logged in ER 2196805.  I did find that attributes can be used to drive the names of the parts in the member selected window.
Regards, Ben
Thank you for your intereset.
I think this is the only solution by now.
Frank.
Hi Ben,
could you please explain how to use attributes to drive the names of the parts.
thank you,
Anton
