Data translators
While using data translators (like STEP, IGES), How to check weather the part is fully translated or not ?
Re: Data translators
Check your export directory for *.log files; these are plain text files that report any errors or other issues encountered during the export process.
Also, check the file by creating a new part file in NX and importing the geometry to the new file (this is sometimes referred to as "round-tripping": NX -> neutral format -> NX). If there are errors when the geometry is re-imported to NX, chances are there will be errors when importing it to a different CAD system as well.
thanks
