Define 3D printer
Builder
Builder
Dear all,
How is it possible to define 3d printer in NX. I mean I want to see my 3d printer options in 3d print dialogbox in NX.
Thank you
Sina Shojaee
Re: Define 3D printer
Builder
Builder
Thank you @cubalibre00
My question is about how NX could recognize my 3d printer.
As you can see in 3d print dialog box there is an option to select 3d printer device. But I can't configure NX to show my 3d pinter options in NX.
Sina Shojaee
Is the 3D Printer defined in windows?   since it must be  "A 3D printer that supports Microsoft Windows 3D print drivers."
-Dave
Hi @Sina,
1) The 3D printer must support Microsoft Windows 3D print drivers
2) You must have a workstation with 8.1 or above OS and Microsoft Windows 3D print drivers installed in this workstation
3) NX 11 installed
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
Wat kind of printer do you use?
If you use for your printer the cura software there is a interface to export your model direct to cura from NX.
This tool supports NX10 and higher.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
