Define directory during export step in commandline
i am launching  and loading input model to NX9.0 via commandline. but on export to step file it is not poiting to the directory from where i am loading the input model. which Environment variable i should change?
4 REPLIES 4
Re: Define directory during export step in commandline
Can you show us your command line ?
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
please find attachment
I don't know perl language (if I'm not mistaken) , but i have the same problem (windows os) if my file is drag and drop on my shortcut with <start in> is defined...
It's not a solution ,in the past , i used this exe : ugnx_cad2prt.exe https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help/#uid:id557706
I hope this helps
www.adgroupe.com
my input file is .prt itself,i have to export it into any other format(step,iges,part.etc)
 https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help/#uid:id557706 as per this i cannot import .prt  Smiley Sad
