Define symbol in NX11
Does anybody encountered the problem that in NX11 you cannot define/save custom drafting symbol?
I tried it in NX10 and it worked, but in NX11 did not.
Thanks for your help!
Re: Define symbol in NX11
What problem are you facing?
Ganesh
It does not save the the symbol.
I select the symbol folder, symbol contents, anchor point, fill the symbol name, part file name and it shows an error message after I click Apply.
Hi @Crypto,
Do you have latest Maintenance Release/Maintenance Pack installed?
There are some similar problems reported to GTAC related to NX 11. If that problem occurs with latest MR/MP then you should report this to GTAC with necessary data (part file,log file etc).
Ganesh
Here's the possible issue and resolution: PR 8318005
Fixed in NX11.0.1 and NX11.0 mp2
Regards, Ben
