Deformable component
Honored Contributor
Honored Contributor
NX 11.
I'm trying to make a deformable component, for a flexure.  All I need to change to alter the defomration, is an angle, but so far I have had no luck.
Angle is the expression the user should be prompted for, when adding to an assembly.
What am I missing?
-Dave
Re: Deformable component
It looks like it is the way you have started the sketch on the csys, I deleted the csys and recreated the deformable so it doesn't require references and it works fine.deform.jpg deformed.jpg
