Delete Check Mate results
how do I delete the result of a check mate test? Thank you
Re: Delete Check Mate results
Does this help?
Right click on the test and choose Delete Result:
yes thank you, but I would also like to delete the entire test, not only the single item. Do you know if there is a way?
It depends on whether you're using Teamcenter or NX to store them.
Larry Carpenter, P.E.
