Deleting duplicated sheets from igs
I have opened a igs file containing quite complex geometry that is duplicated. Islas there a quick way to delete the duplicated sheets?
4 REPLIES 4
Re: Deleting duplicated sheets from igs
There is a journal here that might be of some use.
另一种方法是,删除的时候使用选择工具快速选择
这样可以吗?希望帮到你。
Thank you both.
There is no solid bodies in the igs file so, when selecting solid bodies only, nothing is imported.
Trying the journal in NX12 gives the error attached.
如果可以的画可以给我IGS文件。我能看看是什么情况。
如果只有片体没有实体,可以适当给大公差,或者建模里缝合。
