Deselect no-sectioned component in view
I've a view with a sectioned component. In this view I need to be sectioned. How I deselect this component ?
Thank you...
Using NX1867
RuleDesigner PDM
Re: Deselect no-sectioned component in view
Use the "section in view" command (edit -> view -> section in view...); in the "action" section of the dialog, there is an option to "make sectioned" or "make non-sectioned".
