Detail (Letter Format)
is it possible to configure the Detail-Letter Format that a detail in a drawing starts with the letter "Z" instead of "A"
I could not find a way to change that.
We would like that details start with Z follwoed by Y, X and so on.
Thanks!
Thomas
7 REPLIES 7
Re: Detail (Letter Format)
Hi @TomK76 ,
I believe automatic alphabetically descending order for detail view letter is not possible.
Amol
Hi @AmolKadam
Thanks for your info!
Thomas
@AmolKadam  do you know if there would be a way running a journal which renames the details according to what I need?
Thomas
Can you cite a drafting standard (ASME, ISO, etc.) that allows this?
In general, NX Drafting is set up to follow the standard you select.
@Ken_A Sorry I dont´t know what you mean by that?
Thomas
You can set the desired drafting standard in customer defaults:
*In general*
- If something is specified in a drafting standard, Siemens tends to (eventually) implement it.
- If it is just some company-specific oddity (and NOT in a standard), you'll have to get a lot of support from other users (post your ER number for others to support) to get Siemens interested...
(If you don't know, ER = Enhancement request - start by filing an IR with GTAC or your local reseller)
