Detail View how to change its place ?
Hello
Detail View how to change its place ? ( Change existing one's place )
4 REPLIES 4
Re: Detail View how to change its place ?
Klick right Mouse Button in the FNT or on the view boundary and choose "edit"
greetings Andre
I have only Settings(=Lettering,Stacking,Common,Detail ) and Properties(does nothing).
  • Tried dragging the view with shift pressed and such.
Select the actual detail view > Edit, once 'Detail View' dialog opens, you can move/resize boundary on parent view.
Ganesh Kadole
greetings,
Andre
