Detailing #step file
Hi guys again i need your help...Today i got a .iges (assembly file) file of my new product from my customer i have to do detailing for some parts in the assembly file..I extract the specified part but i can't do the detailing...I here attached the file kindly give a help to do detailing of the attached part..
Re: Detailing #step file
Can you elaborate?
By "detailing", are you referring to Drafting?  If so, what is the problem?
Are you not able to start the Drafting application or is there some other issue?
Regards, Ben
NX (v17 - 1876) | Teamcenter (9 - 12)
When you process this geometry down into 2D drafting, the arc and curves are "splines".  You could probably draw sketch curves over the geometry and constrain it.  You could also try to recreate this geometry.   Sorry.
