Die Design problem while trying to generate stamping die.
Hello everyone! I need your help ASAP!! I want to make a stamping die from a mesh (that i have convert to surface). Everytime i draw the aprropriate punch, blank and flange profile, i specify base orientation and i press ok in order to excecute the process. My problem is that after doing all that procedure, the die dont be generated and i can't figure out the reason why because there isn't any warning pop up to show me that i am doing something wrong. Did anyone have the same problem?
Thanks in advance!
Re: Die Design problem while trying to generate stamping die.
This will be difficult to identify without the data. Suggest you log an issue with GTAC hotline and upload the data to them.
Steve V
