Difference between convert to sheet metal and sheet metal from solid body
 whats  the  Difference between convert to sheet metal and sheet metal from solid body  this option in nx 8.5
5 REPLIES 5
Re: Difference between convert to sheet metal and sheet metal from solid body
Hi Creator, Convert to sheet metal convert a non-sheet metal part to a valid sheet metal part so that you can perform sheet metal operations like bending, unbending, flattening, and so on. You can convert solid models and imported non-sheet metal parts to sheet metal parts. Converting solid models The solid models must have a constant thickness. You cannot convert a sheet body to a sheet metal part.The solid model is created in the Modeling application and then converted to a valid sheet metal part using the Convert to Sheet Metal command.
https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help#uid:sm_from_solid_options Better you go with this site.
RRG
Please refer NX Help Documentation for detail.
: You can select the faces from the solid to be panel (web) faces, and edges between the faces to be bend regions
: It convert all of the thin shell body.
  So you must make solid body to look like sheet metal body, as posible as.
 Sunkap Ahn, Senior Support Engineer
logo
can u you show some videos of this
You can find so many videos about NX tools from YouTube.
logo
Hello @S7,
  • Sheet Metal from Solid 'creates' a new sheet metal feature by selecting faces from a solid body
    Generally used when you want to 'wrap' sheet metal around a volume
  • Convert to Sheet Metal evaluates the existing geometry and internally identifies it as a sheet metal citezen... if it can.
    Generally used when the body resembles a sheet metal part
Have a look at the movie below that shows these basic differences.
(view in My Videos)
