Differences between Mass weight in named solid and asserted weight in part family spreadsheet-NX10
Siemens Builder Siemens Builder
Siemens Builder
hi experts!
----(several questions about managing Part Families in NX10)----,
someone know about documents for clearly explain the difference
beetween the columns about mass weight in named solids and asserted weight.
Futhermore I need documentation about how to proceed to get information to
fill cells in spreadsheet and about Attributes too.
How have I put Attributes on Parts and then fill cells in spreadsheet with these values?
Thanks in advaced for your help!!
Re: Differences between Mass weight in named solid and asserted weight in part family spreadsheet-NX
You can refer to the following link for more information on asserted weight.
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help#uid:func_details_analy_wt_assert
Ganesh
you can always  add attributes to the parent part of the family.
If you add the attributes to a column you can fill them in excel.
when creating the members all added attribute columns will be added in the members.
In excel you can also use the concatenate sum function to reuse some values to create for example a description.
for part family you can add:
  • Epxressions
  • features
  • mirror
  • density
  • Material
  • Asserted Mass
  • Attributes
  • components.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
