05-10-2017 02:40 AM - edited
If I place a dimension on a isometric view the dimensions shows the distance projected on the sheet, not the real distance that exist between the points in the 3D file. Is there a way to make NX show the real distance?
Solved! Go to Solution.
05-10-2017 03:53 AM
Apologies for straying away from the main subject but i guess it will be more easier to do it using PMI then using drafting tools only. Please ignore my response if you do not wish to use PMI.
Best Regards
Kapil
05-10-2017 06:19 AM
Switch the dimension to "true length"
Style => Annotation Style => Dimensions => True Lenght
05-10-2017 10:04 AM
Kapilsharma, I think we cant use PMI with our license, anyway I appreciate your answer.
FlightAssistOn, that is what I was looking for. Thank you!
05-10-2017 01:41 PM
One other way is, Expand the Isometric View > Orient the WCS (Menu > Format > WCS > Orient) as needed > Create the dimensions.
Refer the youtube video for the same.
Creating Dimensions in Isometric Views
Ganesh
#IngenuityIsNX | NX - What's New
