Dimensioning units
I am creating a draft for a part. Both draft file and the part are in inches, but when i use rapid dimension on a part´s view, the units for the dimensions are shown in mm. Can someone help me set up inches?
Thank you.
Re: Dimensioning units
Hi @SergioG,
So "File > Properties > Displayed Part" for both the model and drawing parts shows "Units: Inches"?
Right click on the Drawing Sheet in the Part Navigator and choose "Edit Sheet" and then expand the Settings block on the Sheet dialog - what does it show for Units?
You can change the units of your dimensions by selecting "Menu > Preferences > Drafting".
Go to "[+] Dimension > [+] Text > Units" and change the Units.
Regards, Ben
In the drafting application, go to menu -> preferences -> drafting, then go to dimension -> text -> units and select the desired units to use. Also make this change in your drafting template and save the template; this will save your preference for future drawings that you create from the template.
Edit: @BenBroad was quicker on the draw...  Smiley Happy
