Dimetric view as default view
Is it possible to assign a dimetric view as default?
I mean when I start a new model I would like to see the csys in the D6 dimetric view as Initial View because it would be easier to pick the planes than in the Isometric or Trimetric but in the Customer Defaults I could not choose anything like Dimetric or custom.
Thank you,
Zsolt
Re: Dimetric view as default view
Edit your template file to use whatever settings you like. New files based on the template will inherit the settings.
It works. Thank you!
