Display symbol assemblies
I have a problem for display a symbol
file > new > symbol.prt
application > drafting
Switch between sheet display to modeling view display
menu > insert > symbol > Custom
Exp. Ship Symbol Library
       --- Symbol_mm
           ---Endcut
             ---profile_encut
file > new > assy_symbol.prt
application > Assemblies
menu > Asssemblies > Components > Add component
and now i don't see my symbol (symbol.prt) in assy_symbol.prt
Is it possible ? I'm wrong ?
Thanks for your help
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
Re: Display symbol assemblies
Which reference set is loaded for the part in the assembly.
In NX a part can have different reference sets in an assembly. In the part file it self you don't see that. ( only from the reference set feature you can see what is set in the different reference sets.)
Also check If you worked with layers If the layers is visible.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Reference set > Entire part
Layers > all visible
www.adgroupe.com
Did you see the symbol also not in drafting?
When it is a custom symbol I don't know If you will see it in modeling
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
reference set Entire part not included my symbol ( in symbol.prt) , with new reference set it's ok
sorry
thanks Ruud
www.adgroupe.com
