Drafting: Page number in title block
Good day,
While drafting a title block in NX 12, what is the way to set a cell to be populated automatically with the sheet number? I ask this because i´m working with a file that has several sheets. If i edit the title block with the corresponding sheet number (sheet 4 of 25 for example), it is updated for all the sheets.
I´m sure there´s a function for this, but i ignore it.
Thanks.
Re: Drafting: Page number in title block
Hi @SergioG,
The syntax that is provided with the default title blocks is as follows:
SHEET <W@$SH_SHEET_NUMBER> OF <W@$SH_NUMBER_OF_SHEETS>
Hopefully this will give you what you need.
Regards, Ben
