Drafting Views; Scale list is too limited
Hi all,
Is there a way to customize the scale list of the drawing views?
Here's what I mean:
2019-01-09_17.gifNX Drafting; Too limited scale list.
Every time I need something smaller then 1:10 e.g. 1:20 I need to click ratio and enter manually 2 fields.
and I place my view.
And oops , I then see 1:25 would have been better...
No problem, Just RMB the view, go to ratio again and then this:
2019-01-09_18.gifNX Drawing View Scale plain stupid
So then I need to change two values again... Smiley Frustrated
2019-01-09_19.gifNX Drawing View Scale corrected
I filed ER 1865398 for this on 16-sep-2011.
If you feel in the same situation please add yourself to the list... Smiley Wink
Huysmans Metalen n.v.
2x NX 12.0.2.9 Mach Designer
on Win10 64bit
NX Beta Tester with focus on Sheet Metal
Command Finder is your friend
