Drafting mode - view alignment
Hello, is there a way to ensure that aligned and projected views always stay in line with each other?  I tried to move some views over and they became mis-aligned with their parent or child views.  Thanks
Re: Drafting mode - view alignment
Right click on the projected view and choose "view alignment"; from here you can associate the view position to the parent view (or break associativities as needed).
Great!  Thanks for the help.  I looked around in the drafting preferences, but couldn't find anything.  Sounds like an easy fix.
Hi @s_hightower,
View alignment preference can be found by
Menu > Preferences > Drafting.
View >> Workflow >> Alignment
Ganesh
I just checked my drafting preferences and noticed that I already have the alignement "Associative" checked, so it is turned on.  I had hoped, that if this was selected, it would be impossible or at least prompt me before I moved a view out of alignment with another view.  Is it possible that I still have a setting wrong?  It's quite disturbing that I can accidently move a view out of alignment with another view and I'm not even notified.  If I tried to move a view in another CAD software I used, the parent view would also move with it (stay aligned) or I just wouldn't be able to move the view I was trying to move.  (If it couldn't move and stay aligned with the parent view, it would just not let me).
I just tried Cowski1's response from last week and it worked:
Is there a way to make this work by default or does this have to be manually done every time?  I ready have the drafting preferences set for the views to be aligned, but views can still be dragged out of alignment.
Hi @s_hightower,
Assuming alignment 'Associative' option is checked under drafting preferences.
After placing the base view, does 'Projected View' dialog has option 'Associative Alignment' checked? If not, then just reset the dialog. You will see that option is checked and projected views will be continued to be aligned with base view associatively.
Ganesh
