Drafting-section view-Revolve
Hello NX Design Community
We have a problem with the view that is created during the section view tool (we use Nx 10)
When we create a normal section view  (normal/stepped) from an view (top,right etc), we can change the settings of the shading on the view (wireframe, or fully shadet etc)
Creating with the same tool a revolve section you cannot find the shading setting available to change, and the only think you get is wireframe.
Even if we try with custom sketch for the section.
Is there any way to change the shading when you do a revolve section?
Re: Drafting-section view-Revolve
Per the documentation, neither revolved section views nor unfolded section views are supported for shading.
https://docs.plm.automation.siemens.com/tdoc/nx/10.0.3/nx_help/#uid:index_drafting:id700849:xid61236...
GTAC has submitted an Enhancement Request 1900312 requesting this functionality be added to NX.
Thank you for the info i appreciate it.
