Drafting sketch to modeling
I have a sketch in drafting that I need to use to create an extrude in modeling. Can someone tell me the best way to get my drafting sketch in modeling?
Re: Drafting sketch to modeling
What NX version are you using?  You can utilize NX 2d Layout (there are some good videos on the same in our Knowledge base)
Kapil
You can also right click the view (where the sketch is) and use COPY TO 3D option to copy the sketch curves to modeling.
Kapil
Version 10.0.3.5
I'm not seeing that option...
Hi @Dan_Ruth,
If you often need sketch profile, you can define it as reusable object which then become the part of 'Reuse Library'. Once it is there you can reuse it in modeling as well as drafting application. I have explained the process using NX 9, so it should be the same in NX 10.
In drafting, create a sketch.
Switch to 'Reuse Library' navigator > Select '2D Section Library' > RMB > Define Reusable Object.
Select the sketch, give some meaningful name > OK.
In Modeling application from Reuse Library navigator select the profile, drag and drop on the desired plane to paste the sketch profile.
In Drafting application from Reuse Library navigator select the profile, drag and drop in drawing sheet area to paste the sketch profile at desired location.
Also attached video of the same process.
Ganesh Kadole
This looks like it would work perfectly for what I want to do but forwhatever reason, Define Reusable Object is grayed out. Not sure whats going one here... Would it have anything to do with being in a managed environment?
Here is a small video for copy to 3d
Kapil
(view in My Videos)
One for reusable sketch (as Ganesh explained)...
(view in My Videos)
Ok, that's it. When I am using NX while be managed by TeamCenter the Define Reusable Object is grayed out. When I am not connected to TC, Define Reusable Object is available.
