Drafting template
Hi guys,
When I mark as template a drafting, some options should appear like :
  • Add symbols to region
  • Template Region
And to customize my template I would like to insert autonome view with a specific orientation. But I don't have the orientation setting.
Does some of you have an idea, license, setting something else ?
Thank you
Adrien Marmy, Designer / SystemManager CAx, Turck Interprox
Production: NX12.0.2.mp4 | AGILE PLM E6.1.3 | ECU 3.9.9.3
Development: .NET Testing: NX18**
7 REPLIES 7
Re: Drafting template
Hi @AMA_TRCK ,
Please see below video to create a template:
(view in My Videos)
When drafting template is open or you've just marked it, additional options will be visible:TemplateOptions.JPG
Prerequisite is mentioned in documentaion: Template RegionAdding objects to a region
Samadhan
NX Help Links: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Hi @SamadhanGaikwad ,
Thank for your quick reply.
I have tried has you describe in the video. Please see in the picture below : template part.PNG
Sorry for the french layout.
As you can see I don't have those three more features.
I have tested it with our 4 bundles available (ADV5axes, Millfound, NX12100N and NX11110)
With which license did you run your demo ?
Best regards
Adrien
Are you still not seeing after marking it as template?
Samadhan
Yes exactly still net seeing it.
If you have an idea I am all in 😉
@AMA_TRCK , you'll need nx_drawing_auto license. The changes were  made from NX10 which requires this license to use following functionalities:
- Booklets, templates, regions, rules, automation wizard.
Samadhan
@SamadhanGaikwad  Thank you very much !
Can you tell me how do you find this info and where ?
Best regards
Adrien
@AMA_TRCK , actually I found it in with internal PR (Problem Report), you better confirm or get its more details with GTAC.
Samadhan
