Drawing preferences questions
Hello community,
Anyone knows how to activate the option "SCALE" in drawing preferences?
I need to change the scale in the general menu so I do not have to change it in the pieces one by one each time I take them to the plane. The default scale is 1: 1
Thanks to all
Re: Drawing preferences questions
did you try to edit the sheet scale?
Right click on sheet and then edit sheet. change the scale here will change the view scale and also the start value when placing a view by using base view.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi Ruud, No, I did not try. It is a good way to do it. I thought it could be configured in preferences. Thank you so much for your help
