Drawing template creation
Builder
Builder
Dear all,
I have created new drawing templates for our company and also I have updated pax files. It means I have access to my templates in file>new command and when I create new drawing I can see my own templates. But when I want to create the second sheet I can't see my template any more.
Please tell me what should I do to have my templates in drawings with more than one sheet. I use NX 11.
Thank you in advance.
Sina Shojaee
Re: Drawing template creation
Ciao,
when you add a new sheet be sure to check the use template button.
Ciao
You edited/updated both the drawing and sheet .pax files?
-Dave
Builder
Builder
Hi @Cesare
Thank you for your response.
If I check the use template botton NX will use it's default templates for Siemens.
If I use Standard size I will see a blank sheet. But in the first page everything is OK
Sina Shojaee
Builder
Builder
Hi @DaveK
After creating template I marked it as template and created new pax file in ugii>template folder. So now I have a new template and a new pax file in that folder.
Sina Shojaee
There is another, separate .pax file for secondary sheets (default name: ugs_sheet_templates.pax). These will show up on the "insert sheet" menu but not on the "new drawing" menu.
Check your log file and search for ".pax" to see all of the template .pax files that get loaded when NX starts.
Builder
Builder
Hi @cowski1
Thank you. I created pax file two times and put the second one in drafting > templates Folder and the problem fixed. Your solutions are always very helpful.
Sina Shojaee
