Dual dimension with tolerances
I have a drawing that is using dual dimensions and I can't find how to align the stacked dimensions with the arrow lines. The software is defaulting to aligning the top line of text with the arrow line.
I have attached a pdf for explaination
Re: Dual dimension with tolerances
Unfortunately, you can't center a dual dimension on the dimension line until NX 12.
Thanks DEckhoff, I was afraid of that...
