EDMD Collaboration
 We are trying to use EDMD Collaboration between NX 8.5 and Expedition thru PCB Exchange software.
When importing a baseline idx file from Expedition to NX, it fails with a message: "Bad Board profile, could not extrude it".
Does anybody has some experience in the subject?
Is it a problem with the version of the idx file? and if so is there a way to change it in the PCB Exchange settings.
Regard
 Moti Eitan
 IAI Elta Systems.
Let me rephrase:
 Does anybody use the ECAD MCAD Collaboration with PCB Exchange?
Re: EDMD Collaboration
Solved on NX11
