ER: Add ability to use multiple assembly load options
Below find an ER of mine, if you find it useful, feel free to ask GTAC to be added to ER#7331952.
                            ER Template
Short Description of desired enhancement: <Problem rather than a solution>
    It is not possible to have fallback mechanisms for assembly load options.
What activity in your process is the product not able to currently handle?
    For example, it is not possible to first use load "from folder", if the component is not found use "from search folders", last use "as saved".
What result are you trying to achieve? (Please provide as many details as possible.)
    Being able to load project parts from the location of the assembly part or relative paths to the location of the assembly part
    and standard parts, electrode fixtures, manufacturing fixtures, machine tools, etc. from search folders.
Do you currently have a workaround?
    No
Do you have a proposal for the solution you envision Siemens PLM providing for this capability?
    Replace the load option dropdown with multiple selections for first, second, third, etc.
What is the level of productivity gained from such an enhancement?
    HIGH, easier way to specify locations for standard parts
Other information:
