ERROR OPENING PRT (DRAFT) FILE
Hello everyone
Does anyone have any idea what this error means?
I'm starting to work with NX 12.00 but
I was some days working with this file (draft)
and today I can not open it to continue and it shows me
The following screen:
I thank you for your help.
Re: ERROR OPENING PRT (DRAFT) FILE
Hi @ANGEL74,
I looked up previous issues based on the error number and it looks like you'll have to open an IR with GTAC so that they can forward the part to development to see if can be repaired.
Regards, Ben
thank you very much, Ben
I have experienced the same error in NX 12 when working in manufacturing. Modeling seems to work ok for me in 12.
Kurt Neubaecker
CAD/CAM Designer
Proficient Industries
Cleveland, Ohio
The majority of the issues I had found were related to files containing manufacturing data.
Regards, Ben
In this case it is a drafting that contains some cad models;
what has my attention is that it has already happened to me twice in the same way. I have already reported the incident with technical support.
best
Angel.
We are also having the same problem with NX12.00  ( NX CAM )
Supports says that they now what is the problem and that they are working on it.
thanks for the info
Any word on a potential fix for this problem. I lost another file to it.
Kurt Neubaecker
CAD/CAM Designer
Cleveland, Ohio
Hi @Kneubaecker,
Open an IR with GTAC, upload your problem parts and reference PR 8984975.
It appears that development may have found the root-cause and have successfully corrected some of the part files that demonstrate this problem.
Regards, Ben
