Re: EXPORT STEP PROBLEM WITH WINDOWS 10 UPDATE
I also had a problem with exporting from NX which we we tracked down to drivers, but found a particular range of drivers which did work. Nvidia drivers in the 380's did work, but drivers before or after that doid not work.
Desafortunadamente la solucion sugerida ( guardar como...) no funciona en el caso de exportar elementos seleccionados, por lo que para algunos, como es mi caso, no será funcional.
Esta solucion te obliga a exportar todo el documento.
¿Qué versión de NX estás usando? Este problema se corrigió en NX 11.0.2 mp13.
Uninstall the current graphics driver and install the certified driver as per the GTAC provided excel sheet.
It will work 100%.
Not true! I am using the correct driver and this issue is still present. I can export files fine, I just can't import anything I export. It doesn't work.
Which version of NX?
No issues with NX12.0.2.
Rob Newcomb, Design and Engineering manager
Elmhirst Industries, Specializing in Prototype sheet metal stampings and assemblies
Production: NX 12.0.2 / Autoform r8 /WorkNC 2020.0
Testing:NX 1855
PC: Rave Cadbeast: Intel(R) i7-4790K CPU @ 4.GHz /32gb ram /NVIDIA Quadro P2000 on Win10 Pro
NX 11.0.2.7
Some of us aren't as fortunate to be on NX 12 yet Smiley Sad
@srowell wrote:
NX 11.0.2.7
You need to download and install NX 11.0.2 maintenance pack 13.
Regards, Ben
Which graphics driver version are you running? We found that a windows 10 update installed newer drivers automatically which caused a problem.  If an Nvidia card, we found that drivers older or newer than in the 380's did not work before MP8.
I'm running driver version  385.73  with NX11 MP5 to get import and export to work.
