Easy question
I can't recall what is the key sequence to switch between line and arc segments when using the "profile" curve function in sketcher. I've tried the usually suspects like A and L, arrow keys, ctrl, shift..I just can't remember the magic key sequence. All help is appreciated!
3 REPLIES 3
Re: Easy question
Use mouse gesture click-hold-drag to switch to arc, next curve will revert to line
Re: Easy question
Yep. something so easy...yet know real documentation that I could find! Thank you
Re: Easy question
@RyanM,
It could be more obvious... but it's documented on Step 7 on this page.
Regards, Ben
NX (v17 - 1872) | Teamcenter (9 - 12)
