Edge blend error
Hi all,
Im not sure why I am getting this error. The below shown edge does not take blend(Preview pops up as correct).
I have removed the edge with extrude cut still te problem is same. I have tried with edge blend settings also.
Any one have solution?
3 REPLIES 3
Re: Edge blend error
Hi @Devraj_Mendon ,
Try applying blend to adjacent edges also. It might solve the problem.
Amol
Can you share the file?
Hi @Devraj_Mendon
It is hard to give you an exact guideline without seeing the model...
But you can try a smaller radius with edge blend and then try to make it larger step by step with resize blend.
It has sometimes worked for me.
You can try face blend too.
