Edit name of NX 11.0.2
Builder
Builder
Hello@NX Experts,
as per we last discussed as edit name @NX main menu bar, i cant do that in NX 11.0.2,
image attached as below
is there any chnges in that or i am doing some mistake,
as per guide of mr.Benbroad,, i do that as follows:
VERSION 120
EDIT UG_GATEWAY_MAIN_MENUBAR
TITLE ** NX ROCKS **
link follow as  : https://community.plm.automation.siemens.com/t5/NX-Design-Forum/Edit-name-of-NX/m-p/374950#M9336
I took help by local NX documentation,b ut where I am wrong, i can't get that,
anybody have an idea for this
appreciated for your help
Warm Regards
Thomas Roman
Machine Designer
Re: Edit name of NX 11.0.2
It can be don in NX 11.0.2.   I'd recheck your steps, verify you are editing the correct file, and that the proper env variables are set.
-Dave
Also verified this in NX 11.0.2, and works fine fore me as well. Could it be the * in your name?
Kind regards,
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
Good point, I recall having issues with special characters in the past.
-Dave
Builder
Builder
Hello@DaveK & DennisdeBrouwer,
can you please upload the text or .men file for it, i wanna cross check it
& what are you make label in Enviroment etc
thanks
Warm Regards
Thomas Roman
Machine Designer
We use the NX_custom setup files, originally created by Rob Cohon, now maintainted by Gerrit, both of Siemens PLM, so my directory paths are probabaly different than yours.
From the readme file that comes with NX custom:
NXcustom Menuscript                                 Last Modified: 19Aug2016
Use the Menuscript folder to share modifications to NX menus with multiple users.  These modificaitons can be referenced by ribbon files.
The following line in the NX110custom\NX110library\NX110env.dat file controls the location and folder name of the Menuscript folder:
UGII_VENDOR_DIR=${NX_CUSTOM_LIB}\Menuscript
and my "edit_ug_main.men" file looks like this:
VERSION 120
TITLE CGR-NX11_custom
BEFORE UG_HELP
CASCADE_BUTTON NXCUSTOM
  LABEL NX&custom
END_OF_BEFORE
MENU NXCUSTOM
CASCADE_BUTTON NXCUSTOM_UTILS
  LABEL &Utilities
BUTTON NX_CUSTOM_ABOUT
  LABEL &About NXcustom
  MESSAGE Displays what's new and revision history
  ACTIONS "start /b \"Title\" notepad \"%NX_CUSTOM_LIB%\about.txt\" "
BUTTON NX_CUSTOM_HELP
  LABEL NXcustom &Help
  MESSAGE Displays setup information
  ACTIONS "start /b \"Title\" notepad \"%NX_CUSTOM_DIR%\README.txt\" "
END_OF_MENU
AFTER UG_FILE_CLOSE
 BUTTON UG_FILE_REOPEN_ALL
 LABEL Close/Reopen Modified Parts
 ACTIONS STANDARD
END_OF_AFTER
AFTER UG_TOOLS_CUSTOMIZE
    BUTTON MY_CALC
    LABEL Calculator
    ACTIONS "start /b calc.exe"
END_OF_AFTER
MENU NXCUSTOM_UTILS
BUTTON NX_CUSTOM_BAT
  LABEL Edit NX.&Bat File
  MESSAGE Edit the NX batch file
 ACTIONS "start /b \"Title\" notepad \"%NX_CUSTOM_DIR%\%NX_Number%.bat\" "
BUTTON NX_COMMON_BAT
  LABEL Edit NX Co&mmon.Bat File
  MESSAGE Edit the NX Common Settings batch file
 ACTIONS "start /b \"Title\" notepad \"%NX_CUSTOM_LIB%\%NX_Number%common.bat\" "
BUTTON NX_CUSTOM_ENV
  LABEL Edit NX &Env.Dat File
  MESSAGE Edit the NX environment variables file
 ACTIONS "start /b \"Title\" notepad \"%NX_CUSTOM_LIB%\%NX_Number%env.dat\" "
BUTTON NX_ROUTING_ENV
  LABEL Edit NX &Routing.Env File
  MESSAGE Edit the NX Routing environment variables file
 ACTIONS "start /b \"Title\" notepad \"%NX_CUSTOM_LIB%\%NX_Number%env_routing.dat\" "
BUTTON NX_EDIT_MAIN_MENU
  LABEL Edit &Main Menu File
  MESSAGE Edit the Main Menuscript menu file
 ACTIONS "start /b \"Title\" notepad \"%NX_CUSTOM_LIB%\Menuscript\startup\edit_ug_main.men\" "
BUTTON NX_EDIT_CUSTOM_RIBBON
  LABEL Edit NXcustom.&rtb File
  MESSAGE Edit the NXcustom Ribbon file
 ACTIONS "start /b \"Title\" notepad \"%NX_CUSTOM_LIB%\ToolBars\startup\NXcustom.rtb\" "
BUTTON NX_CUSTOM_PROMPT
  LABEL NX &Command Prompt
  MESSAGE NX Command
  ACTIONS " %comspec% /c start \"%NX_NUMBER% Command Prompt\" %comspec% /X /T:70 "
END_OF_MENU
-Dave
Builder
Builder
Hello@DaveK
i did that,
now where i have to save this file in system,
& how to link with it to NX,
what will the environment variable fo this,,
can you please share this details with avi file or detail
i did this many time ago,, i forgot this,,
appriciated for your help
Warm Regards
Thomas Roman
Machine Designer
Is this for a single installation?  or company wide?  I've only done it for company wide setups, and all of these custom files are located on a network drive, thus my setup is different than one that would be company wide.
I would try setting the variable UGII_VENDOR_DIR= to whatever location you want to put the edited file, but put the file in a sub folder called "startup"
Example:
UGII_VENDOR_DIR=c:\\CustomStuff\
and place the file here:  c:\\CustomStuff\startup
-Dave
Builder
Builder
hello@buddy
facing this type of error as shown as image
Warm Regards
Thomas Roman
Machine Designer
Can you either post the file you are using or the text from the file? It seems you have a formatting error now.
Scott
