Editing line geometry in NX 10
Good morning,
  Just switched over to NX10 from 8.5 and am having some issues in editing basic curve geometry. Previously, we were able to double-click a curve and along with a Edit Curve pop up there would be a pop up with XYZ coordinates, arc and arc length. AND the ability to change line length direction whether it was a straight line or arc.
THe question, is this option now gone or is it an option that needs turned on ? Trying to figure out the new system, a new workstation, a hot project and Catia training all at once so some help would be appreciated.
Kirk
“The moment you doubt whether you can fly, you cease for ever to be able to do it.”
― J.M. Barrie, Peter Pan
Re: Editing line geometry in NX 10
Honored Contributor
Honored Contributor
Check the customer default: Curves -> general -> enable legacy edit curve parameters. You will need to restart NX for the setting to take effect.
After double clicking a curve, select the Start/End (Cone symbol) to extend or  vertices points to move XYZ.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
Still doesn't work. Smiley Sad
________________________________
Meggitt (Rockmart), Inc d/b/a Meggitt Polymers & Composites
This e-mail may contain proprietary information and/or copyright material. This e-mail is intended for the use of the addressee only. Any unauthorized use may be unlawful. If you receive this e-mail by mistake, please advise the sender immediately by using the reply facility in your e-mail software.
Information contained in and/or attached to this document may be subject to export control regulations of the European Community, USA, or other countries. Each recipient of this document is responsible to ensure that usage and/or transfer of any information contained in this document complies with all relevant export control regulations. If you are in any doubt about the export control restrictions that apply to this information, please contact the sender immediately.
Be aware that Meggitt may monitor incoming and outgoing e-mails to ensure compliance with the Meggitt IT Use policy.
Honored Contributor
Honored Contributor
Are we talking about the tracking bar?
If so, there are instructions in the following thread to get it back:
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/NX-10-Basic-Curves/m-p/327295/highli...
And that fixed it !
Many thanks,
Kirk
