Electrical routing: ugroute_elec.xml location
Hello, Is it possible to change where NX looks for the ugroute_elec.xml location?  I'm trying to open Electrical Routing and I get a warning stating that it can't open the application view.  It then gives a location where to look, but it's the wrong address.  Thanks
Re: Electrical routing: ugroute_elec.xml location
May be yes...but please wait for other replies also..
If i am not wrong then the ugii_env_ug.dat file contain all the information regarding these locations. These will determine where from the ugroute_elec_metric.xml /ugroute_elec_inch.xml files are accessed.
Best Regards
Kapil
Hello, Just an update.  Our helpdesk got back to me and had me add an address for a mapped network drive into the "Manual Entries" area of the UG Application Selector and that fixed the problem.  Thanks for the info.
Have the same problem (but for mechanical routing)
Can't find the UG Application Selector. How do I find it?
Hello @Daniel_Jansson,  At least for our setup, if you select "NX Utilities in the NX Selection Menu, NX Application Selector is the first option.
Hi @Daniel_Jansson,
There can be various reasons why the application view is not loading.  What is the exact message that gets displayed in your dialog and what does it say at the bottom of your NX log file (Menu > Help > Log File)?
@s_hightower, you appear to be using a customized setup which would only apply to your environment.
Regards, Ben
@BenBroad, that is good to know.  I've only used "NX" at this location, so wasn't sure what was custom and what was out of the box.  I've used an earlier version of UG in 1999, but a "few" things have changed since then.
