Environment Variables for render
Hi, I would like to centralize all the customizations of rendering (that is, all that is in the two main directories ${UGII_BASE_DIR}\ugstudio\ and ${UGII_BASE_DIR}\ugphoto); but I have noticed that there are quite a lot of variables about rendering.
Maybe there is a single variable that can be set above them all?
Thankyou
L
Re: Environment Variables for render
Hi Laurus,
I am certainly not the right person to answer this query but i guess ugstudio and ugphoto cover all the env variables pertaining to rendering.
Best Regards
Kapil
thank you Kapil, but how can I centralize those two directories (ugstudio
and ugphoto)?
Laura
if i'm searching in the NX log file i see that the following to variables are looking the the folders of UGPHOTO and UGSTUDIO, i don't know if this will cover al the settings.
UGII_LI_LAYLA_DIR for ugphoto
UGII_TEXTURE_TIFF_IMAGE_DIR for ugstudio
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
thank you very much!
Good the see that it works!
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
