Error During Update..
Good day colleagues,
After updating sketch and applying mirror feature i faced with this error message:
Main problem is not error,  i couldnt close it and i had to restart NX and lost my data.
mauby someone faced with that problem and how could i avoid that problem in future ?
Thank you.
P.S. sorry for english.
3 REPLIES 3
Re: Error During Update..
"how could i avoid that problem in future?"
The message: "There is an object which depends on itself" indicates that you had created a circular dependency. NX doesn't like that. Don't do that.
I ran into same error. Obviously I made a mistake by creating a circular reference however I was "punished" with having to restart NX to exit the warnings loop. As a future reference, is there a normal way to end it and correct the error without losing the previous job?
@DenisDubas & @41Degree
The fact that you had to kill NX and lose data is not normal behavior for the system. Please submit an IR through GTAC or your local support group.
Abe
