Error_While_Installing_NX_10.0.03_Maintenance_Documentation
Builder
Builder
Hello Guys ,
                      I am tired from this error
                     while i try to install nx 10.0.3 maintence pack documentation , i get this horrible error on my system ,  if you have any advise please share  ,
                       the error screen shot is like this
Capture_Error.JPGThis error make me angry while i install documentation update
Warm Regards
Thomas Roman
Machine Designer
4 REPLIES 4
Re: Error_While_Installing_NX_10.0.03_Maintenance_Documentation
Siemens Genius Siemens Genius
Siemens Genius
I ran this problem by the developer of the install. That error message is generic and implies the file cannot be found. He suggests you browse to the location of the .bat file (I:\nxdocs_update1003) then double click on the nxdocs_update.bat file to manually run the file and see if the install works.
If not, you should enter an IR with GTAC on the problem.
NX Design Apps Documentation & Courseware Manager
Builder
Builder
Hello@Gregg Makepeace
                                              I tried that but the error not solved , Have you got another way to solve this problem
Warm Regards
Thomas Roman
Machine Designer
Siemens Genius
You should log an IR with GTAC for your problem so they can assess your configuration and better understand what could be causing this error.
Builder
Builder
Hello@Gregg_Makepeace,
                                                   Thanks for Support@Gregg_Makepeace.
Warm Regards
Thomas Roman
Machine Designer
