Re: Error durring import IGES file
Hello
after testing on my workstation and on a VM workstation it seems to be an issue with enviroment settings.
In an test enviroment your sample file reads in with no errors. But in our production enviroment not.
I found that in our NX11 production enviroment the NX10 IGES def file is read which results that NX11 searchs for the wrong igesnull-part.
So first of all you should test the IGES translation with an OOTB installation and then compare the settings of your production enviroment to the settings in the OOTB installation:
In the NX log files search for IGES_DIR and compare the results.
Meinolf, , Leistritz Turbinentechnik GmbH
Production: NX10.0.3, TC 10.1.4
Testing:NX11 Beta
@Triumphator wrote:
Hello
Hello @Triumphator
I have solved it by reinstaling the display driver. Thank you very much for the help that you provided.
Hello to all,
I have posted detailed answer on this topic with solution how I have solved the problem. I don't know why the answer has not appeared.
Problem solved when I installed the latest display driver for my NVIDIA Quadro M5000M (Notebook Driver Release R384 U4 (385.69)).
Best,
Danijel
