Error on export dxf
I'm trying to export to dxf a drawing but an error occurs.
Thank you...
Using NX1867
RuleDesigner PDM
7 REPLIES 7
Re: Error on export dxf
Hi @cubalibre00 ,
  1. Check if correct NX version dxfdwg library is loaded/configured.
  2. Try after copy-paste of libdxfdwg.dll from another machine. it might have corrupted somehow during install/upgrade or failure during install.
And last option (if nothing worked, keep this option last) is this: Uninstall-Reinstall NX. Check below link:
What it really means when GTAC advises to "uninstall and reinstall NX" (Windows platform)?
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
hI @SamadhanGaikwad ,
the error was gone, but the export doesn't give eny result. I will open an IR.
Thank you...
Using NX1867
RuleDesigner PDM
Hi @SamadhanGaikwad ,
GTAC show only NX1855 on selection version, but Siemens PLM has released NX1859.
Thank you...
Using NX1867
RuleDesigner PDM
I see the same.
@BenBroad , Does it take specific time to reflect latest release version ?
I see the same.
Hi @GaneshKadole , I don't know, but I notified the powers that be.
... and it's been updated. That was a quick turnaround!!
The solution is to copy the DXFDWG folder from NX1859 to our shared DXFDWG folder.
The same for UGTO2D folder.
Thank you...
Using NX1867
RuleDesigner PDM
