Error when activating drawing
When I try and activate a drawing that I recently worked on with no problems, I am receiving the following error,
"Diaplay operation attempted on non-displayable object"
It will not allow me to activate it.
Has anyone seen this error or know what it means or how to fix it?
I am working in NX 9.0.3.4
Thank you.
Re: Error when activating drawing
try turning your partial loading off when opening up your drawing.  Also try looking in your LOG file under the Help.  If you can not find a smoking gun I would call GTAC or search the GTAC database for some key words in your error message.
Also, try running a part cleanup.
